How to use android app to control LM
(28.04.2021, 05:31)admin Wrote: You can use a WebSocket connection to read/write object values. There are built-in JavaScript libraries in LM that can be used in your app if using Cordova (https://cordova.apache.org/) instead of native Android app SDK. See this thread for more info: https://forum.logicmachine.net/showthread.php?tid=525
Hi Admin,
Let me understand.
If I am going to implement a websocket server in LM, I first create a resident script with this script under:
Do I have to change anything in this script or add something?
local copas = require'copas' -- create a copas webserver and start listening local server = require'websocket'.server.copas.listen {   -- listen on port 8080   port = 8080,   -- the protocols field holds   --   key: protocol name   --   value: callback on new connection   protocols = {     -- this callback is called, whenever a new client connects.     -- ws is a new websocket instance     echo = function(ws)       while true do         local message = ws:receive()         if message then            ws:send(message)         else            ws:close()            return         end       end     end   } } -- use the copas loop copas.loop()
RE: How to use android app to control LM - by Alexander - 11.05.2021, 20:58
