BIM ioT
1. Create a user library named bim-iot using the attached source.
2. Make sure that the updated websocket library and keys are in place.
3. Create a resident script with sleep time = 0:
if not wsclient then   require('json')   require('user.bim-iot')   url = 'wss://test-hub.usbim.com'   wsclient = require('user.websocket').client('sync', 1)   opts = {     protocol = 'tlsv13',     key = '/home/ftp/key.pem',     password = [[*q&'wrKQsx+#bj8pbEV=%7Gpr"S+sxV2ngr`N}SjCC`X#rtt!wY6PL`d2'3!^x}u]],     certificate = '/home/ftp/cert.pem',     cafile = '/home/ftp/ca-chain.cert.pem',   }   res, err = wsclient:connect(url, opts)   if res then     log('WS connection OK')   else     log('WS connection failed', err)     wsclient:sock_close()     wsclient = nil   end   if not lb then     lb = require('localbus').new()     lb:sethandler('groupwrite', eventhandler)     lb:sethandler('groupresponse', eventhandler)     lbfd = lb:getfd()   end   wsfd = wsclient.sock:getfd()   init()   sendall() end if wsclient then   local res, lbstat, wsstat = socket.xselect(10, lbfd, wsfd)   if res > 0 then     if lbstat then       lb:step()     end     if wsstat then       local msg, opcode, clean, code, reason = wsclient:receive()       log(msg, opcode, clean, code, reason)       if msg then         onwsmessage(msg)       elseif reason ~= 'timeout' then         log('WS connection dropped', reason)         wsclient:sock_close()         wsclient = nil       end     end   end else   -- handle incoming object messages before trying to reconnect WS   lb:loop(10) end
Since I don't have the tools to test some parts might not work.
.lua   bim-iot.lua (Size: 2.85 KB / Downloads: 15)
BIM ioT - by gdimaria - 06.05.2021, 15:05
RE: BIM ioT - by admin - 06.05.2021, 15:08
RE: BIM ioT - by gdimaria - 07.05.2021, 07:54
RE: BIM ioT - by gdimaria - 06.05.2021, 15:11
RE: BIM ioT - by admin - 07.05.2021, 07:59
RE: BIM ioT - by gdimaria - 10.05.2021, 16:16
RE: BIM ioT - by admin - 11.05.2021, 07:08
RE: BIM ioT - by gdimaria - 11.05.2021, 09:30
RE: BIM ioT - by admin - 11.05.2021, 09:32
RE: BIM ioT - by gdimaria - 11.05.2021, 09:41
RE: BIM ioT - by admin - 11.05.2021, 09:42
RE: BIM ioT - by gdimaria - 11.05.2021, 10:24
RE: BIM ioT - by admin - 13.05.2021, 06:23
RE: BIM ioT - by gdimaria - 13.05.2021, 09:05
RE: BIM ioT - by admin - 13.05.2021, 09:06
RE: BIM ioT - by gdimaria - 13.05.2021, 09:51
RE: BIM ioT - by admin - 13.05.2021, 09:53
RE: BIM ioT - by gdimaria - 13.05.2021, 10:01
RE: BIM ioT - by gdimaria - 28.05.2021, 11:07
RE: BIM ioT - by admin - 28.05.2021, 13:57
RE: BIM ioT - by gdimaria - 06.06.2021, 16:35
RE: BIM ioT - by admin - 07.06.2021, 09:59
RE: BIM ioT - by gdimaria - 09.06.2021, 15:17
RE: BIM ioT - by admin - 10.06.2021, 06:05
RE: BIM ioT - by gdimaria - 10.06.2021, 07:48
RE: BIM ioT - by admin - 10.06.2021, 07:53
RE: BIM ioT - by gdimaria - 10.06.2021, 08:26
RE: BIM ioT - by gdimaria - 10.06.2021, 09:27
RE: BIM ioT - by admin - 10.06.2021, 10:03
RE: BIM ioT - by gdimaria - 10.06.2021, 17:34
