15.05.2021, 11:21
(This post was last modified: 15.05.2021, 11:25 by Monolithos.)
	(14.05.2021, 11:20)Erwin van der Zwart Wrote: Well we already have Prosumer Home as a solution for this based on W4K..
https://www.se.com/de/de/work/products/p...r-home.jsp
I also created several scripts to do some load balance, even controlling our EV chargers based on available power.. To be honest, those scripts are quite simple so I don’t use prosumer but modify the scripts i have on custom needs is much faster..
Hello Edgars and Erwin,
I was made aware by a belgian Schneider business manager something like this was coming... I had no idea something is already avaliable.
I know a Magelis industrial pc unit can be used to manage up to 50 G4 ev-charging points but without (out-of-the-box and as far I was informed anyway) any possibility to interact with other technologies (like KNX or batteries or pv-invertor).
As far as I can deduct (German is not a language I am comfortable with) this Prosumer Home products is already based on LM hardware and uses the EEbus protocol to manage other home appliances (however, online documentation is very limited) but seems to focus on ev-charging.
It's not clear to me wether this uses the standard Homelynk/wiser software or some other pre-loaded application.
Also, recently I followed some webinars organised by the KNX association. The main subject in one of these was protocols used to manage the energy sources and users in order to have total energymanagement (local en wide area smart grids). EEbus was mentioned as one the minor and therefor not significant protocols, not very likely to become an industry-standard. I wouldn't know since I'm no expert.
KNX itself is apparently also looking into extending the protocol to support the market needs.
Anyway, all very interesting but a little too in-depth for a small electrotechnical installer.
@Edgars,
In short, I'm looking for a residential solutions to :
1) prevent the main power switch of tripping when total power consumption is too high with easy configuration of priorities (e.g. cooking over ev-charging, ev-charging over battery charging, battery discharging over net-based electricity)
2) optmize self-consumption and peak-shaving by intelligently using all technologies available (pv-panels, batterijs, electrical vehicle, hot water reservoir, high consumption household appliiances (washing and dish-washing machines, dryers, boilers, heat-pumps, ...), taking into account the users priorities and expectations (e.g. car must be charged at..., clothing must be dry by..., ...)
3) intelligent load-balancing and power-sourcing : adjusting ev-charging power based on available solar power (dynamicly), load-balancing when mutliple charging points are in use (residential-wise, up to 2 can be expected - some manufacturers like Alfen use a lan-based communication to establisch self-management and divide the available power, others use a master-slave setup, some use hardware switches for power throttling and the rest depend on external control), injecting and buying energy based on dynamic transaction tarrifs, ...)
4) supervision and user-interfacing for all the above
All this in an easy to configure package at a reasonable price-tag :-)
Many units (invertor, ev-chargers,...) depend on measurements provided by Modbus meters or can be controlled via Modbus. Both Modbus and Bacnet both go a long way in the HVAC-world and KNX is a good go-between in other places since many products have some kind of KNX-gateway.
Right know, many solutions exist to advice consumers into what to do and when, with fancy dashboard presentations, based on power measurements. But not many (if any) are able to take action to actually optimize.
If they can, it's mostly cloud-based (equals privacy issues, manufacturer dependancy and last but not least too slow to have dynamic interactions) and hardware-dependant or too expensive for residential use.
Too many different protocols to take into account is probably the main problem, followed by not enough knowledge amongst the installers (myself included) to get a system working.
That's why the LM came to mind.
I would be happy to give aid in any effort although, due lack of programming skills, it would be limited to present a integrator/end-user point-of-view :-)
Kind regards,
Hendrik
