Modbus RTU to TCP bridging
Did you unlock the locking pad on the IFM interface?
• protected by password where a password is required in the command
• protected by configuration: ◦ with the IFM interface, the remote control commands are enabled when the locking pad on the IFM interface is in the open position.
In sample below the used password is 0000 (ASCII 00 = 00110000 00110000 => 12336 in Decimal)
require('luamodbus') mb = luamodbus.rtu() mb:open('/dev/RS485', 19200, 'E', 8, 1, 'H') mb:connect() mb:setslave(1) if event.getvalue() == true then   mb:writeregisters(7999, 904, 10, 4353,1,12336,12336,0,0,0,0,0,0,0,0,0,0,0,8019,8020,8021) -- Open command else   mb:writeregisters(7999, 905, 10, 4353,1,12336,12336,0,0,0,0,0,0,0,0,0,0,0,8019,8020,8021) -- Close command end mb:close()
RE: Modbus RTU to TCP bridging - by Daniel - 20.05.2021, 07:37
RE: Modbus RTU to TCP bridging - by Daniel - 21.05.2021, 07:42
RE: Modbus RTU to TCP bridging - by admin - 21.05.2021, 13:06
RE: Modbus RTU to TCP bridging - by Erwin van der Zwart - 25.05.2021, 08:57
RE: Modbus RTU to TCP bridging - by cekca - 27.05.2021, 07:27
