Log on html widget
You can place it via an iframe similar to this example: https://forum.logicmachine.net/showthread.php?tid=3331
Keep in mind that this will work only locally, not via cloud.
Code for logs.lp:
<!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <link rel="stylesheet" href="/apps/css/bootstrap.css"> </head> <body> <table class="table table-striped"> <tr>   <th>Date/time</th>   <th>Script name</th>   <th>Log</th> </tr> <? require('apps') items = db:getall([[   SELECT * FROM logs   ORDER BY logtime DESC   LIMIT 50 ]]) for _, item in ipairs(items) do   datetime = os.date('%Y.%m.%d %H:%M:%S', item.logtime) ?> <tr>   <td><?=datetime?></td>   <td><?=escape(item.scriptname)?></td>   <td><?=escape(item.log)?></td> </tr> <? end ?> </table> </body> </html>
Log on html widget - by CristianAgata - 28.05.2021, 17:03
RE: Log on html widget - by admin - 31.05.2021, 09:00
