How change objects color at visu
#20
Use this, make sure that all lower/upper limit objects are defined and they all follow the naming scheme as you've posted.
$(function() {   $('.color-by-value').each(function(_, el) {     var addr = $(el).data('object');     if (addr) {       grp.listen(addr, function(obj) {         var value = obj.value;         var name = obj.name;         var color = 'green';         var lname = name.replace('ACTUAL_TEMP', 'LOWER_LIMIT');         var uname = name.replace('ACTUAL_TEMP', 'UPPER_LIMIT');         var llimit = grp.getvalue(lname);         var ulimit = grp.getvalue(uname);         if (value < llimit) {           color = 'blue';         }         else if (value > ulimit) {           color = 'red';         }         $(el).css('color', color);       });     }   }); });
How change objects color at visu - by AlexLV - 17.03.2019, 21:43
RE: How change objects color at visu - by admin - 10.06.2021, 06:30
