PJLINK to Panasonic Projector
You either need a resident or a scheduled script depending on how often you want to read the status.
Try this example, you might need to install 2021 firmware as *r pattern is not supported in older firmwares. Change IP/port as needed. If the status read works then the script can be modified to write info into objects.
sock = require('socket').tcp() sock:settimeout(1) res, err = sock:connect('192.168.1.98', 4352) if res then   res, err = sock:receive('*r')      if res and res == 'PJLINK 0' then     sock:send('%POWR ?\r')     res, err = sock:receive('*r')       log('received powr reply', res, err)     sock:send('%1ERST ?\r')     res, err = sock:receive('*r')       log('received error reply', res, err)     sock:send('%1LAMP ?\r')     res, err = sock:receive('*r')       log('received lamp reply', res, err)   else     log('receive init failed', res, err)   end else   log('connect failed', err) end sock:close()
RE: PJLINK to Panasonic Projector - by admin - 22.04.2020, 14:55
RE: PJLINK to Panasonic Projector - by admin - 22.04.2020, 15:33
RE: PJLINK to Panasonic Projector - by admin - 10.06.2021, 12:46
RE: PJLINK to Panasonic Projector - by admin - 11.06.2021, 10:12
