DALI RS485 Gateway
(21.06.2021, 06:39)admin Wrote: "reply timeout" means that the gateway sent the request to the DALI bus but there was not reply. This indicates that at least the RS-485 communication part on the GW-2 is working correctly. Check the RS-485 wiring for GW-1 and also check if the on-board LED turns on when the on-board button is pressed.
Hi!
Checked the wiring yesterday, From lm -> GW1 -> GW2 ok.
Tested the led, ok. works on both.
DALI RS485 Gateway - by Bobby - 20.06.2021, 11:22
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 06:12
RE: DALI RS485 Gateway - by admin - 21.06.2021, 06:13
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 06:16
RE: DALI RS485 Gateway - by admin - 21.06.2021, 06:17
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 06:22
RE: DALI RS485 Gateway - by admin - 21.06.2021, 06:25
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 06:35
RE: DALI RS485 Gateway - by admin - 21.06.2021, 06:39
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 07:49
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 12:12
RE: DALI RS485 Gateway - by admin - 21.06.2021, 12:14
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 12:18
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 12:15
RE: DALI RS485 Gateway - by admin - 21.06.2021, 12:18
RE: DALI RS485 Gateway - by admin - 21.06.2021, 12:24
RE: DALI RS485 Gateway - by Bobby - 21.06.2021, 12:27
RE: DALI RS485 Gateway - by batistacaceres - 23.07.2023, 21:31
RE: DALI RS485 Gateway - by admin - 24.07.2023, 06:20
