Wiser performance metrics
Well, currently the UI in my environment seems to display incorrect statistics, for example, I see around 20% of TP load, while in the scripts mentioned (I'll paste below) it's around 9% - that's quite a difference:
UI:
[Image: XFqy4zh.png]
Using the script:
[Image: XO4l4co.png]
I was trying to understand what is the cause, and what I found is that W4K (incorrectly) includes IP TX/RX as part of the TP bus load, but those packets are not going over TP.
Isn't that a bug?
The script I use is a version of what you linked:
-- KNX bus load maxS = 30  -- highest assumed telegram rate pr second - same as in wiser knx stats view maxM = maxS*60 -- needs to be equal to this script's sleep interval data = knxlib.getstats() if data then   sent = data.tptx -- + data.iptx -- if you want to see also KNX IP stats   received = data.tprx -- + data.iprx -- if you want to see also KNX IP stats   repeats = data.repeats   traffic = sent + received + repeats     if knx_prev then     knx_load = ((traffic - knx_prev)*100)/ maxM     grp.update('Wiser KNX bus load', knx_load)   end     knx_prev = traffic end
About the bus load using throughput instead of rate, well I would prefer to have 100% correct information than 99% correct, when both options are equal in complexity to deliver, but it's your choice as a vendor of course to decide on the priorities of solving different problems.  I think this "good enough" logic is a bug, although of a low severity Smile
Thank you!
Morkov
Wiser performance metrics - by morkovka - 27.08.2021, 08:05
RE: Wiser performance metrics - by Daniel - 27.08.2021, 08:31
RE: Wiser performance metrics - by morkovka - 27.08.2021, 14:38
RE: Wiser performance metrics - by admin - 27.08.2021, 14:40
RE: Wiser performance metrics - by morkovka - 27.08.2021, 18:59
RE: Wiser performance metrics - by morkovka - 30.08.2021, 06:02
RE: Wiser performance metrics - by admin - 30.08.2021, 06:17
RE: Wiser performance metrics - by morkovka - 30.08.2021, 07:56
RE: Wiser performance metrics - by admin - 30.08.2021, 13:33
RE: Wiser performance metrics - by morkovka - 30.08.2021, 13:49
RE: Wiser performance metrics - by morkovka - 30.08.2021, 19:22
