30.09.2021, 07:06
You can simply create a profile and set the datatype field to float32. You can also use Read test to check the correctness beforehand. Use the same float32 data type and try setting Read swap to None if the value is incorrect. If it still does not work then try reading from the register 70 instead of 71.
