Google Smart Home Assistant
Great work! I've quickly tested and found few issues that should be easy to fix:
1) For the curtain object, move direction is reversed. I.e. if i say "close curtain", it sends Open command to the Open/Close object in LM. Should be vice versa. Also i don't know if it's home assistant fault or not, but Curtain does not have graphics representation in google home, only generic icon which opens object properties.
2) I couldn't set up thermostat – selection filters what it seems to be 1 byte objects, but skips HVAC Mode (which are also 1 byte, but separate type). Without this object thermostat is inactive in Google Home. On the side note, i don't believe a lot of knx thermostats supports Off mode setting, so should be there separate setting for on/off and more advanced mapping within the integration? In case on/off object is not set up, integration should always supply ON state.
Google Smart Home Assistant - by Daniel - 12.10.2021, 08:39
RE: Google Smart Home Assistant - by myg - 15.10.2021, 12:11
RE: Google Smart Home Assistant - by Daniel - 15.10.2021, 12:34
RE: Google Smart Home Assistant - by myg - 15.10.2021, 12:58
RE: Google Smart Home Assistant - by myg - 15.10.2021, 17:55
RE: Google Smart Home Assistant - by Jørn - 27.10.2021, 09:01
RE: Google Smart Home Assistant - by Daniel - 27.10.2021, 09:07
RE: Google Smart Home Assistant - by Daniel - 28.10.2021, 13:46
RE: Google Smart Home Assistant - by myg - 03.11.2021, 14:56
RE: Google Smart Home Assistant - by Daniel - 03.11.2021, 14:57
RE: Google Smart Home Assistant - by khalil - 04.11.2021, 08:13
RE: Google Smart Home Assistant - by Daniel - 04.11.2021, 08:22
RE: Google Smart Home Assistant - by Thomas - 18.11.2021, 19:11
RE: Google Smart Home Assistant - by Daniel - 19.11.2021, 08:27
RE: Google Smart Home Assistant - by Thomas - 19.11.2021, 11:10
RE: Google Smart Home Assistant - by Daniel - 19.11.2021, 11:25
RE: Google Smart Home Assistant - by Daniel - 22.11.2021, 14:40
RE: Google Smart Home Assistant - by Thomas - 23.11.2021, 18:46
RE: Google Smart Home Assistant - by Thomas - 26.11.2021, 13:33
RE: Google Smart Home Assistant - by Daniel - 26.11.2021, 13:45
RE: Google Smart Home Assistant - by anysma - 02.12.2021, 16:03
RE: Google Smart Home Assistant - by Daniel - 02.12.2021, 16:47
RE: Google Smart Home Assistant - by anysma - 03.12.2021, 12:54
RE: Google Smart Home Assistant - by Daniel - 03.12.2021, 13:27
RE: Google Smart Home Assistant - by Evens - 15.10.2022, 21:06
RE: Google Smart Home Assistant - by Daniel - 17.10.2022, 08:06
RE: Google Smart Home Assistant - by Jørn - 12.11.2022, 16:58
RE: Google Smart Home Assistant - by admin - 14.11.2022, 07:39
RE: Google Smart Home Assistant - by Long - 19.03.2023, 10:16
RE: Google Smart Home Assistant - by Daniel - 20.03.2023, 08:46
RE: Google Smart Home Assistant - by Jørn - 24.09.2023, 08:31
RE: Google Smart Home Assistant - by Jørn - 18.01.2025, 09:52
RE: Google Smart Home Assistant - by admin - 20.01.2025, 12:41
RE: Google Smart Home Assistant - by Jørn - 20.01.2025, 16:55
RE: Google Smart Home Assistant - by Daniel - 22.12.2025, 09:20
RE: Google Smart Home Assistant - by myg - 17.03.2026, 14:27
RE: Google Smart Home Assistant - by admin - 17.03.2026, 14:32
RE: Google Smart Home Assistant - by myg - 17.03.2026, 17:49
RE: Google Smart Home Assistant - by admin - 17.03.2026, 17:51
RE: Google Smart Home Assistant - by myg - 17.03.2026, 17:58
RE: Google Smart Home Assistant - by myg - 23.03.2026, 10:02
RE: Google Smart Home Assistant - by admin - 24.03.2026, 07:36
