Mosaic beta Custom Widget value send problem
(27.10.2021, 18:54)tpospichal Wrote:
(27.10.2021, 13:00)admin Wrote: Mosaic30-beta has been updated, see if it works for you.
Hello yes perfect working. I have another bug. Fixed value send widget has a big space in front of the title. Maybe another ones also has the problem, but i mostly use widgets from widget creator.
Just a question is there any possiblility to make smaller margin (zero is the best option ) under widget title? Then i can make customs widgets with 1x1 size.
It is .widget-title css class. Probably better option is make the value selectable, because it will affect all old mosaic visualizations. Default widgets are much bigger than needed.
Thank you
+99999
RE: Mosaic beta Custom Widget value send problem - by alexll - 27.10.2021, 20:09
