01.12.2021, 01:12
Now i have had a night of extended testing at home, playing with local network, wifi network and firewall/NAT at home. All along i have had 6 continious ping logging going against router, switch, Wifi controller and logic-machine. Same logging from 2 different pc's, one at ethernet cable and one over Wifi.
Can't find any correlation with the faults i experience with LM freezing up due to changes in network (cheked even the spanning tree and LACP protocols)
In LM i tried to disable/remove Amazon alexa app, google home app, also disabled zerotier. No change.
I'm left with the Moasic app, canx apps and zigbee app installed, with same results.
I notice problem arize when i close moasic and comes back to dashboard in LM app on android. Then everyting freezes, including local access in webbrowser on pc.
In some accation i however reach the system over cloud access from the app if i force close it on android and opens again. Cloud opens fine and I can control system, but no response/connection on local control.
All the time i have normal ping response from the device from the two pc's who is logging the system. So it's seems to be ok on the network side.
I starting to have a feeling something is wrong with the moasic system. It seems to happen if i navigate around moasic and close moasic back to dashboard.
Could it be som kind of token that is not released/closed and wait's for a timeout, hence the wait time with no response, or some kind of user blocking due to some error?
