Problem with Routing function and programming devices
(31.08.2018, 08:36)admin Wrote: Routing on LM can only be used for group communication (this is done for security reasons). If your LM is connected to KNX TP you must set connection mode to TP-UART. Keep IP features enabled and routing will work as well. For TP device programming you need to connect to each LM via tunneling.
Hi admin, is routing still only used for group communication?
I need to programming through LM in routing mode because I have no TP, it is possible now?
RE: Problem with Routing function and programming devices - by Mirco - 16.02.2022, 13:33
