LoRA project
First thing to keep in mind is that with larger distance the antennas must be mounted higher no matter which technology is used. For example the height should be at least 5m for 300m distance and 868MHz frequency (LoRaWAN). Our LoRa solution uses 433MHz frequency so the height should be at least 7.2m. You can use this tools for calculation: https://www.everythingrf.com/rf-calculat...calculator
LoRaWAN can be a solution but you will need additional hardware - LoRaWAN gateway. You will also need LoRaWAN server software. It's possible to run it on LM but it's rather complicated to set up. There's a cloud solution - The Things Network, but I would not recommend using a cloud-only solutions.
Our LoRa hardware solution might work but it's not recommended for outdoor usage because the hardware does not have any protection from condensation.
LoRA project - by gdimaria - 25.03.2022, 12:26
RE: LoRA project - by admin - 25.03.2022, 12:51
RE: LoRA project - by gdimaria - 25.03.2022, 13:07
RE: LoRA project - by admin - 25.03.2022, 13:22
RE: LoRA project - by gdimaria - 25.03.2022, 13:44
RE: LoRA project - by admin - 25.03.2022, 13:53
