27.04.2022, 08:09
(27.04.2022, 07:05)admin Wrote: You cannot use both client and server on the same port. But it's possible to run both if server is using non-default port (not 47808).Hi ,
Thank you for your reply,
I changed the port to 4800 (Network,Bacnet setting, port), after that the Simens BACnet server can't see any object from the LM5 same with YABE, the BACnet server is enabled in LM5 and the points are exported.
I did return the old port 47808 and it's the same none could see any BACnet from the lm5.
