Exchange data between two LM5
(05.08.2022, 09:43)admin Wrote: If you only need to send data one way then you can connect both LMs to the same ZeroTier network and use remote services (HTTP requests) to send data periodically. Use IP addresses assigned by ZeroTier for communication not LM internal IP. Remote services docs: https://openrb.com/docs/remote-new.htm
Hi again,
yes it's just one way, in fact, I will have to send 20 objects from one LM to the other
Could you please give me one example?
lm1 IP address is 192.168.191.79
lm2 IP address is 192.168.191.181
I want to send the object 10/0/2 2byte float from LM1 to LM2, Should I create an object in lm2 and write a script in that object  to read that value from lm1?
Exchange data between two LM5 - by Fahd - 05.08.2022, 09:39
RE: Exchange data between two LM5 - by admin - 05.08.2022, 09:43
RE: Exchange data between two LM5 - by Fahd - 05.08.2022, 09:57
RE: Exchange data between two LM5 - by Daniel - 05.08.2022, 11:10
RE: Exchange data between two LM5 - by Fahd - 05.08.2022, 12:41
RE: Exchange data between two LM5 - by Daniel - 05.08.2022, 12:44
RE: Exchange data between two LM5 - by admin - 04.12.2024, 11:30
RE: Exchange data between two LM5 - by Daniel - 18.12.2024, 14:48
RE: Exchange data between two LM5 - by admin - 17.12.2025, 09:38
RE: Exchange data between two LM5 - by Daniel - 17.12.2025, 09:50
RE: Exchange data between two LM5 - by Daniel - 17.12.2025, 14:04
RE: Exchange data between two LM5 - by Daniel - 17.12.2025, 14:45
RE: Exchange data between two LM5 - by Daniel - 18.12.2025, 08:26
