(09.08.2022, 06:27)admin Wrote: If you only need read-only values on the modbus side you can simply periodically update the register values in the resident script itself. Modify register mapping in updateregisters() as needed. Each script must use a unique port (502, 503 etc).
Code:if not mb then require('luamodbus') mb = luamodbus.tcp() mb:open('0.0.0.0', 502) mb:setslave(2) function setint64(grpaddr, regaddr) local value = grp.getvalue(grpaddr) or 0 local raw = knxdatatype.encode(value, dt.int64).dataraw local r1 = raw:byte(2) * 0x100 + raw:byte(1) local r2 = raw:byte(4) * 0x100 + raw:byte(3) local r3 = raw:byte(6) * 0x100 + raw:byte(5) local r4 = raw:byte(8) * 0x100 + raw:byte(7) mb:setregisters(regaddr, r4, r3, r2, r1) end function updateregisters() setint64('32/1/1', 3204) end mb:setmapping(0, 0, 3300, 0) updateregisters() prev = os.time() end mb:handleslave() curr = os.time() if curr ~= prev then updateregisters() prev = curr end
Sorry Admin, using your script (without modify it, except '32/1/1') no communication with Modbus master is possible.
Note : I suspended cyclic "Modbus handler" script and preserved "mbproxy" script in common functions.
Perhaps interesting for you 'timeout ?' > founded by monotoring in log :
res, err = mb:handleslave()
log("mb:handleslave :",res,err)
* arg: 1
* string: mb:handleslave :
* arg: 2
* nil
* arg: 3
* string: timeout
