LM as a Modbus slave : number of slaves
First, check the Error log for any errors.
You can use this test script for reading from local TCP slave with port 502 (check Logs tab for the read result or any errors):
require('luamodbus') mb = luamodbus.tcp() mb:open('127.0.0.1', 502) res, err = mb:connect() if res then   val, err = mb:readregistervalue(3204, 'int64', 'b')      if val then     log('read ok', val)   else     log('read failed', err)   end else   log('connect failed', err) end mb:close()
RE: LM as a Modbus slave : number of slaves - by admin - 09.08.2022, 10:11
