Modbus TCP Polling Delay
(08.09.2022, 11:28)admin Wrote: If you want quick polling you need to use one resident script per each connection because Modbus mapper can only poll one TCP device at a time.
Use this example as a starting point. The connection is kept open between requests. Multiple registers are read at once to speed things up.
if not mb then   require('luamodbus')   mb = luamodbus.tcp()   mb:open('192.168.0.9')     res, err = mb:connect()   if not res then     mb:close()     mb = nil     log('connect failed', err)   end end if mb then   v1, v2, v3 = mb:readregisters(10, 3)   if v1 ~= nil then     grp.checkupdate('1/1/1', v1)     grp.checkupdate('1/1/2', v2)     grp.checkupdate('1/1/3', v3)   else     mb:close()     mb = nil     log('read failed', v2)   end end
Thank you admin, this sounds very interesting. What is the correct sleep interval for this resident script? If I set to 1sec is this going to poll data every 1sec from the slave?
Where can I define the registers I would like to read? I need register 0,1,2 and is it also possible to write to those register the value of the knx object when its changed? So in the end a bi-directional communication with the touch panel over modbus IP.
Until now I was using the following profile with mapped knx objects and worked in both directions. The only issue was the delay.
{   "manufacturer": "Pro-Face",   "description": "Touch Panel GP4301-T GM Blok 02->10 ",   "mapping": [     { "name": "Zone 1 On/Off", "bus_datatype": "1001", "type": "coil", "address": 0, "writable": 1, "write_only": 0 },     { "name": "Zone 2 On/Off", "bus_datatype": "1001", "type": "coil", "address": 1, "writable": 1, "write_only": 0 },     { "name": "Zone 3 On/Off", "bus_datatype": "1001", "type": "coil", "address": 2, "writable": 1, "write_only": 0 }   ] }
Modbus TCP Polling Delay - by manos@dynamitec - 08.09.2022, 10:23
RE: Modbus TCP Polling Delay - by Daniel - 08.09.2022, 10:40
RE: Modbus TCP Polling Delay - by admin - 08.09.2022, 11:28
RE: Modbus TCP Polling Delay - by manos@dynamitec - 08.09.2022, 11:43
RE: Modbus TCP Polling Delay - by admin - 08.09.2022, 11:49
RE: Modbus TCP Polling Delay - by admin - 12.09.2022, 12:08
RE: Modbus TCP Polling Delay - by admin - 14.09.2022, 06:54
