PVPC trend graph in visu
Custom JS code, adjust as needed.
$(function() {   // load chartist CSS   $('<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/chartist/0.11.4/chartist.min.css" type="text/css">').appendTo('head');   // load chartist JS   $.getScript('https://cdnjs.cloudflare.com/ajax/libs/chartist/0.11.4/chartist.min.js', function() {     // create chart container, add it to plan with ID 8     var el = $('<div></div>').css({       position: 'absolute',       width: '400px',       height: '300px',       left: '10px',       top: '50px',       zIndex: 999     }).appendTo('#plan-8');     // load chart data     $.getJSON('/user/data.lp', function(data) {       // create chart       var chart = new Chartist.Line(         el.get(0),         {           labels: [1, 2, 3, 4, 5, 6, 7, 8],           series: [ data ]         },         {           low: 0,           showArea: true         }         );     });   }); });
data.lp should be uploaded via FTP using apps login to the user directory.
For this example it simply generates an array of random numbers:
<? math.randomseed(os.time()) data = {} for i = 1, 8 do   data[ i ] = math.random(0, 10) end json.write(data)
You can also output storage variable that another script creates:
<? require('apps') data = storage.get('my_var_name') json.write(data)
PVPC trend graph in visu - by JRP - 26.08.2022, 10:45
RE: PVPC trend graph in visu - by JRP - 08.09.2022, 10:55
RE: PVPC trend graph in visu - by admin - 08.09.2022, 11:55
RE: PVPC trend graph in visu - by JRP - 08.09.2022, 16:15
RE: PVPC trend graph in visu - by admin - 09.09.2022, 08:48
RE: PVPC trend graph in visu - by JRP - 09.09.2022, 18:03
RE: PVPC trend graph in visu - by admin - 12.09.2022, 09:43
RE: PVPC trend graph in visu - by JRP - 13.09.2022, 18:51
RE: PVPC trend graph in visu - by admin - 14.09.2022, 06:47
RE: PVPC trend graph in visu - by JRP - 14.09.2022, 16:24
RE: PVPC trend graph in visu - by admin - 15.09.2022, 07:15
RE: PVPC trend graph in visu - by JRP - 16.09.2022, 08:41
RE: PVPC trend graph in visu - by JRP - 21.09.2022, 08:36
RE: PVPC trend graph in visu - by admin - 21.09.2022, 08:42
RE: PVPC trend graph in visu - by JRP - 22.09.2022, 18:02
RE: PVPC trend graph in visu - by JRP - 23.09.2022, 10:43
RE: PVPC trend graph in visu - by admin - 23.09.2022, 11:05
RE: PVPC trend graph in visu - by JRP - 23.09.2022, 11:47
RE: PVPC trend graph in visu - by admin - 23.09.2022, 11:50
RE: PVPC trend graph in visu - by JRP - 23.09.2022, 12:09
RE: PVPC trend graph in visu - by admin - 23.09.2022, 12:12
RE: PVPC trend graph in visu - by JRP - 23.09.2022, 12:52
RE: PVPC trend graph in visu - by JRP - 24.09.2022, 11:24
RE: PVPC trend graph in visu - by JRP - 03.10.2022, 09:53
RE: PVPC trend graph in visu - by Daniel - 03.10.2022, 10:07
RE: PVPC trend graph in visu - by JRP - 03.10.2022, 10:35
RE: PVPC trend graph in visu - by admin - 03.10.2022, 13:10
RE: PVPC trend graph in visu - by JRP - 06.10.2022, 17:16
RE: PVPC trend graph in visu - by admin - 07.10.2022, 05:36
RE: PVPC trend graph in visu - by JRP - 16.10.2022, 17:25
RE: PVPC trend graph in visu - by JRP - 18.10.2022, 07:30
RE: PVPC trend graph in visu - by admin - 18.10.2022, 09:31
RE: PVPC trend graph in visu - by JRP - 18.10.2022, 17:30
RE: PVPC trend graph in visu - by JRP - 19.10.2022, 07:41
RE: PVPC trend graph in visu - by admin - 19.10.2022, 07:42
RE: PVPC trend graph in visu - by JRP - 20.10.2022, 18:11
RE: PVPC trend graph in visu - by icuzz - 14.02.2024, 16:43
RE: PVPC trend graph in visu - by admin - 15.02.2024, 08:05
RE: PVPC trend graph in visu - by icuzz - 16.02.2024, 05:20
RE: PVPC trend graph in visu - by admin - 16.02.2024, 07:21
RE: PVPC trend graph in visu - by icuzz - 17.02.2024, 18:18
RE: PVPC trend graph in visu - by admin - 19.02.2024, 06:01
RE: PVPC trend graph in visu - by icuzz - 20.02.2024, 07:21
RE: PVPC trend graph in visu - by icuzz - 01.03.2024, 04:21
