Event log creation and presentation
(21.07.2016, 10:15)admin Wrote: You can use storage engine to create a queue, here's a function that adds an item to a list named eventlog and trims the list to contain up to 1000 entries. Date/time is added automatically, so you only need to supply event text. Create event scripts to log whichever info you need.
function eventlog(text)   local max = 1000 -- max number of entries   -- add formatted date   text = os.date('%a %d/%m/%Y %T ') .. text   storage.exec('lpush', 'eventlog', text)   storage.exec('ltrim', 'eventlog', 0, max - 1) end
To output the list to client side you can create an .lp page and display it in the visualization via iframe. Create a file called eventlog.lp and upload it to user folder via FTP. Set iframe URL to /user/eventlog.lp
<? require('apps') items = storage.exec('lrange', 'eventlog', 0, 999) ?> <!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <title>Event log</title>   <script src="/apps/js/jquery.js.gz"></script>   <link rel="stylesheet" href="/apps/css/bootstrap.css"> </head> <body> <script> $(function() {   var items = <? json.write(items) ?>     , container = $('.container')     , header;   $.each(items, function(index, item) {     var chunks = item.split(' ')       , newheader = chunks.shift() + ' ' + chunks.shift();     // output data header each time it changes     if (newheader != header) {       header = newheader;       $('<h3></h3>').text(header).appendTo(container);     }     // output log entry     $('<p></p>').text(chunks.join(' ')).appendTo(container);   }); }); </script> <div class="container"></div> </body> </html>
Note that newest items come on top of the list.
FTP upload docs: http://forum.logicmachine.net/showthread.php?tid=85
I coudn't diplay eventlog.lp file as a frame, it will display "File not found: /www/user/eventlog.lp".
I uploaded the file via FileZilla as ou can see in the attachment
RE: Even log creation and presentation - by Fahd - 14.09.2022, 11:42
