IP routing through ZeroTier
You can do it via our cloud. Add two LMs to the same network by using same string(you will need to manually accept second LM) then tag objects which you want to pass trough lmcloud on both devices and then they will work in sync.
IP routing through ZeroTier - by cranz - 20.09.2022, 16:36
RE: IP routing through ZeroTier - by Daniel - 21.09.2022, 08:05
RE: IP routing through ZeroTier - by alexll - 25.11.2022, 06:50
RE: IP routing through ZeroTier - by admin - 25.11.2022, 07:22
RE: IP routing through ZeroTier - by alexll - 25.11.2022, 11:08
