21.09.2022, 08:42
You can convert the data on the client side:
This chart library does not work correctly when plan scaling is enabled. See if replacing the URL from "https://cdnjs.cloudflare.com/ajax/libs/chartist/0.11.4/chartist.min.js" to "https://dl.openrb.com/misc/chartist.js" makes it work correctly.
for (var i = 0; i < data.length; i++) {
data[ i ] = data[ i ] / 1000;
var chart = ...This chart library does not work correctly when plan scaling is enabled. See if replacing the URL from "https://cdnjs.cloudflare.com/ajax/libs/chartist/0.11.4/chartist.min.js" to "https://dl.openrb.com/misc/chartist.js" makes it work correctly.
