BACnet troubles connecting
Hi all!
I have an LM4 (Version: 20160927) with BACnet server enabled, and some group addresses exported, but can't get it to work.
In august I made a very similar configuration that worked on the first try (on the beta FW). The biggest difference is that here I have a Cisco SG200 switch between, configured on single VLAN, and different FW version on LM4.
Tried it with direct connection without the switch and got same results. IP adresses are static.
What works:
- Scan from other software (Yabe, Bacnet explorer, ...) when bacnet server is running on the LM4
- Scan from LM4 (when bacnet server is off) - sees all other equipment and can read the values
Doesn't work:
- can't read the datapoints
- LM4 sends I-Am, get no replies
- Other controller sends Who-Has (datapoint from LM4), get no replies
BACnet ID's are unique, port is 0xBAC0 (47808)
Thanks in advance, Z
BACnet troubles connecting - by zoltan - 12.12.2016, 11:04
RE: BACnet troubles connecting - by admin - 12.12.2016, 14:39
RE: BACnet troubles connecting - by zoltan - 13.12.2016, 03:15
RE: BACnet troubles connecting - by zoltan - 13.12.2016, 09:02
RE: BACnet troubles connecting - by admin - 13.12.2016, 09:25
RE: BACnet troubles connecting - by zoltan - 13.12.2016, 09:47
