Dimmer widget on/off button also sending value
I am using TOUCH 3 and a standard "Dimmer rotary" in my Wiser for KNX visualisation.
When pressing the middle button (the on/off button), Wiser seems to send BOTH a 1 bit ON/OFF GA and a 1 byte VALUE GA (of either 0% or 100% depending on whether you turn on or off the lamp). Is this really the case? Can I configure this so that the VALUE is not sent?
Needless to say: The VALUE byte should not be sent as this destroys the "previous" DALI value the next the lamp is switched on.
See pictures below.
Thanks in advance
Dimmer widget on/off button also sending value - by mjaanes - 28.12.2022, 16:59
