31.12.2016, 09:03
(This post was last modified: 31.12.2016, 09:03 by Erwin van der Zwart.)
Hi Habib,
Can you try to use the object only as value, now you use image and value with a transparent png.
I tested with value only and the css is also build for that, if you want with transparent image then i have to check css as there might be a extra class level needed in the css i created.
