best way to store period power usage
(28.02.2022, 08:43)Daniel Wrote: You could make 3 virtual objects and use trends on all 3. Use a fetch function to collect last hour consumption and based on the period add this value to virtula or not. You will be able to compare daily values later only take in to account an hour value shift.
I'm not sure how to collect last hour from trends etc i had a look at trends, fetchone but doc says hour and minute info are ignored, this is what i have so far, anyways to optimize it?, its scheduled script to run every hour
-- Peak 7am-9am | off peak shoulder 9am-5pm | peak 5pm-9pm | off peak shoulder 9pm-11pm | Off-peak night 11pm-7am now =  os.date('*t') local KWH_now = grp.getvalue('1/6/0') function conplete_day_vals() --  get all storage and update obj   peak = storage.get('Peak_val')   shoulder = storage.get('off_peak_shoulder_val')   night = storage.get('off_peak_night_val')     grp.write('32/1/1', peak )   grp.write('32/1/2', shoulder )   grp.write('32/1/3', night) end --************** start ************ if now.hour == 7 then     --off peaknight stop --  and prev day finish   local last = storage.get('off_peak_night')   storage.set('off_peak_night_val',last - KWH_now)    conplete_day_vals()     --peak start   storage.set('Peak_start', KWH_now) end --************** peak stop, off peak, shoulder start ************ if now.hour == 9 then -- peak end   --peak stop   local last = storage.get('Peak_start')   storage.set('Peak_val', KWH_now - last)     --off peak shoulder start   storage.set('off_peak_shoulder_start', KWH_now) end --************** off peak shoulder stop, peak start************ if now.hour == 17 then   --off peak shoulder stop   local last = storage.get('off_peak_shoulder_start')   storage.set('off_peak_shoulder_val', KWH_now - last)       --peak start   storage.set('Peak_start', KWH_now) end --************** peak stop, off peak shoulder start ************ if now.hour == 21 then     --peak stop   local last = storage.get('Peak_val')   storage.set('peak_val', last + storage.get('Peak_start') - KWH_now)     --off peak shoulder start    storage.set('off_peak_shoulder_start', KWH_now) end --************** off peak shoulder stop, off peak night start ************ if now.hour == 23 then     --off peak shoulder stop   local last = storage.get('off_peak_shoulder_val')   storage.set('off_peak_shoulder_val', last + storage.get('off_peak_shoulder_start') - KWH_now)     --off peaknight start   storage.set('off_peak_night', KWH_now) end
RE: best way to store period power usage - by benanderson_475 - 08.01.2023, 20:08
