Modbus TCP slave with LM
(17.01.2023, 12:55)Daniel Wrote: Which script do you use?
-------------------------------------------------------------------------------- -- Wiser For Knx : Modbus esclave TCP/IP -------------------------------------------------------------------------------- -- Simulateur de centrale de mesure pour EcoStruxure EV Charging Expert -------------------------------------------------------------------------------- -- -- Modèle : iEM3x5x pour Bornes de recharge PRO AC -- -------------------------------------------------------------------------------- -- v1.2 du 17/01/2023 - D.Barboyon -------------------------------------------------------------------------------- -- (c) Sigma Tec - 2023 -------------------------------------------------------------------------------- ------------- Paramétrage ------------------------------------------------------ idPort        = 503 -- No de port Modbus/TCP        - toujours >= 502 idSlave       = 3   -- No esclave Modbus/TCP        - toujours >= 2 PMname        = "iEM3155-B2"    -- nom du compteur - long <= 14 car -------------------------------------------------------------------------------- idGroup       = idPort-500        -- idGroup/slaveNum/x idSteMapping1 = 0 idSteMapping2 = 0 idSetMapping3 = 6502 idSteMapping4 = 6502 -- --------------------------------------------------------------------- -- Table des objets Wiser For Knx et registres associés -- --------------------------------------------------------------------- groupList = {   { addr = idGroup, datatype="string"       , name=PMname        ,reg=idPort    , unit=""    , tags="-"},   { addr = idGroup, datatype="uint16"          , name="I1"          ,reg="3000"    , unit="A"   , tags="modbus"},   { addr = idGroup, datatype="uint16"       , name="I2"           ,reg="3002"    , unit="A"   , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="I3"          ,reg="3004"    , unit="A"   , tags="modbus"},   { addr = idGroup, datatype="uint16"         , name="P1"           ,reg="3054"    , unit="kW"  , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="P2"          ,reg="3056"    , unit="kW"  , tags="modbus"},   { addr = idGroup, datatype="uint16"       , name="P3"           ,reg="3058"    , unit="kW"  , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="P"          ,reg="3060"    , unit="kW"  , tags="modbus"},   { addr = idGroup, datatype="uint32"       , name="ET"           ,reg="3204"    , unit="kWh" , tags="modbus"},   { addr = idGroup, datatype="bool"         , name="PH1"           ,reg="true"    , unit=""    , tags="-"},   { addr = idGroup, datatype="bool"         , name="PH2"           ,reg="true"    , unit=""    , tags="-"},   { addr = idGroup, datatype="bool"         , name="PH3"           ,reg="true"    , unit=""    , tags="-"},   { addr = idGroup, datatype="bool"         , name="BTN"           ,reg="true"    , unit=""    , tags="-"},   { addr = idGroup, datatype="unit16"        , name="CURSEUR"    ,reg="true"    , unit="A"   , tags="-"},   { addr = idGroup, datatype="bool"         , name="BTN MONO"    ,reg="false"    , unit=""    , tags="-"},   { addr = idGroup, datatype="bool"         , name="BTN TRI"     ,reg="true"    , unit=""    , tags="-"},   { addr = idGroup, datatype="string"        , name="TYPE MONO-TRI"  ,reg="TRI"    , unit=""    , tags="-"},   { addr = idGroup, datatype="bool"         , name="PHASE MONO"       ,reg="1"    , unit=""    , tags="-"},   { addr = idGroup, datatype="uint16"          , name="I Phase AVG"      ,reg="3010"    , unit="A"   , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="U Phase1"      ,reg="3028"    , unit="V"   , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="U Phase2"      ,reg="3030"    , unit="V"   , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="U Phase3"      ,reg="3032"    , unit="V"   , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="U AVG"      ,reg="3036"    , unit="V"   , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="P apparente"      ,reg="3076"    , unit="kVA" , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="Fact Pu"      ,reg="3084"    , unit=""    , tags="modbus"},   { addr = idGroup, datatype="uint16"          , name="Frequence"      ,reg="3110"    , unit="Hz"  , tags="modbus"},   { addr = idGroup, datatype="uint32"          , name="QT E"          ,reg="3220"    , unit="kVAR", tags="modbus"},   { addr = idGroup, datatype="uint16"       , name="QT P total"       ,reg="3068"    , unit="kVAR", tags="modbus"} }         -- Spécifique Pro AC : reg Modbus 6501 (uint16) = SlaveId obligatoire ------------------------------------------------------------------------ local proacSlaveReg = 6501 -- --------------------------------------------------------------------- -- Gestion de la création des objets Wiser For Knx -- --------------------------------------------------------------------- function ST_grpCreate(STdatatype,STgroup,STname,STcomment,STunits,STtag) ------------------------------------------------------------------------   grp.create({       datatype     = STdatatype,       address     = STgroup,       name         = STname,       comment     = STcomment,       units         = STunits,       tags         = { "EVCE", STname },     }) end -- Scan la table et crée les objets WFK si nécessaire ------------------------------------------------------------------------ for i, groupCurr in ipairs(groupList) do   STgroup = groupCurr.addr.."/"..idSlave.."/"..i     if i == 1 then   -- spécifique objet "nom de la centrale de mesure"     nomGroupe = groupCurr.reg.."#"..idSlave     valGroupe = groupCurr.name     objGroupe = STgroup      -- Update objet "nom de la centrale de mesure"     grp.write(objGroupe, valGroupe)       end     if grp.find(STgroup) then     --existe deja   else       -- crée le groupe     STdatatype       = groupCurr.datatype     STname           = nomGroupe.."-"..groupCurr.name     STcomment       = "-"     STunits           = groupCurr.unit     STtag           = groupCurr.tags     ST_grpCreate(STdatatype,STgroup,STname,STcomment,STunits,STtag)   end end -- ----------------------------------------------- -- Processus MaJ registres Modbus slave -- ----------------------------------------------- if not mb then   log("EVCE cyclic - Modbus #2 : starting mb")     require('luamodbus')   -->>>>>>>>>Modbus slave setting<<<<<<<<<<<<<<<<<<<<<<<<   -- Modbus TCP   ------------------------------------------------------   mb = luamodbus.tcp()   mb:open('0.0.0.0', idPort)   ------------------------------------------------------    -->>>>>>>>><<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<      -- slave id   mb:setslave(idSlave)     -- init slave storage for coils, discrete inputs, holding registers and input registers   mb:setmapping(idSetMapping3, idSetMapping2, idSetMapping3, idSetMapping4)     --*****************************************************   -- >>>>>>>>>>>Coil write callback<<<<<<<<<<<<<<<<<<<<<<   mb:setwritecoilcb(function(coil, value)         if coil == 0 then             grp.write('0/0/12', value, dt.bool)         else             alert('coil: %d = %s', coil, tostring(value))         end   end)   --*****************************************************   -->>>>>>>>>>>Register write callback<<<<<<<<<<<<<<<<<<<   mb:setwriteregistercb(function(register, value)         if register == 0 then             -- send value limited to 0..100             grp.write('0/0/13', math.min(100, value), dt.scale)         else             alert('register: %d = %d', register, value)         end   end)   --*****************************************************       -- spécifique Pro Ac ----------------   addRegister = proacSlaveReg    addRegister = addRegister -1   mb:setregisters(addRegister, idSlave)   -------------------------------------      log("EVCE cyclic - Modbus #2 : END OF starting mb")   end -- Scan la table et Maj des objets autres que Modbus slave ------------------------------------------------------------------------ for i, groupCurr in ipairs(groupList) do     dataType    = groupCurr.datatype     if dataType == "bool" and groupCurr.tags == "-" then        nomGroupe = groupCurr.addr.."/"..idSlave.."/"..i              if grp.find(nomGroupe) then          -- groupe existe         else        grp.write(nomGroupe, groupCurr.reg)           end           end       if dataType == "string" and groupCurr.tags == "-" and i > 1 then       nomGroupe        = groupCurr.addr.."/"..idSlave.."/"..i       if grp.find(nomGroupe) then         -- groupe existe        else       grp.write(nomGroupe, groupCurr.reg)          end        end   end -- Scan la table et MaJ registres Modbus slave ------------------------------------------------------------------------ -- addr = idGroup, datatype="uint16"  , name="I1" ,reg="3000" , unit="A" , tags="" for i, groupCurr in ipairs(groupList) do   addRegister = groupCurr.reg   dataTags    = groupCurr.tags   dataType    = groupCurr.datatype   nomGroupe   = groupCurr.addr.."/"..idSlave.."/"..i     -- valeur courante de l'objet WFK   value = grp.getvalue(nomGroupe)      if dataType == "uint16" and dataTags == "modbus" then         addRegister = addRegister -1     -- dt.float16, dt.float32, dt.int64, dt.int32     raw = knxdatatype.encode(value, dt.float32).dataraw      r1 = raw:byte(1) * 0x100 + raw:byte(2)     r2 = raw:byte(3) * 0x100 + raw:byte(4)              mb:setregisters(addRegister, r1, r2)              --mb:setregisters(addRegister,   r1)     --mb:setregisters(addRegister+1, r2)   end     if dataType == "uint32" and dataTags == "modbus" then     addRegister = addRegister -1        -- dt.float16, dt.float32, dt.int64, dt.int32     raw = knxdatatype.encode(value, dt.int64).dataraw      r1 = raw:byte(1) * 0x100 + raw:byte(2)     r2 = raw:byte(3) * 0x100 + raw:byte(4)     r3 = raw:byte(5) * 0x100 + raw:byte(6)     r4 = raw:byte(7) * 0x100 + raw:byte(8)     mb:setregisters(addRegister, r1, r2, r3, r4)         --mb:setregisters(addRegister,   r1)     --mb:setregisters(addRegister+1, r2)     --mb:setregisters(addRegister+2, r3)     --mb:setregisters(addRegister+3, r4)         end  end mb:handleslave()
Modbus TCP slave with LM - by SigmaTec - 17.01.2023, 12:54
RE: Modbus TCP slave with LM - by Daniel - 17.01.2023, 12:55
RE: Modbus TCP slave with LM - by SigmaTec - 17.01.2023, 13:29
RE: Modbus TCP slave with LM - by admin - 17.01.2023, 13:35
RE: Modbus TCP slave with LM - by SigmaTec - 17.01.2023, 14:06
