Spacelynk USB communication towards FTDI
Hello to all,
I have an issue with the integration of a USB device using Spacelynk.
The 3rd party device can speak with my pc using the usb cable without any issue and I can send commands using different 3rd party softwares.
When I connect the device to Spacelynk using the same usb cable I can identify the usb using the necessary script. It is strange that I see the message about the latency timer. What could be the issue (see the attached image)
In any case the FTDI appear on my spacelynk as "/dev/ttyUSB0".
require('serial') port = serial.open('/dev/ttyUSB0', {  baudrate = 9600,  databits = 8,  stopbits = 1,  parity = 'none',  duplex = 'half' })
I try to open the serial port to write a message but I get the following error:
Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.385584] ftdi_sio ttyUSB0: failed to get modem status: -32 Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.384593] ftdi_sio ttyUSB0: failed to get modem status: -32 Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.383582] ftdi_sio ttyUSB0: urb failed to clear flow control Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.382563] ftdi_sio ttyUSB0: ftdi_set_termios urb failed to set baudrate Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.380585] ftdi_sio ttyUSB0: urb failed to clear flow control Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.379572] ftdi_sio ttyUSB0: ftdi_set_termios urb failed to set baudrate Feb 1 09:47:21 spaceLYnk kern.err kernel: [ 1092.378572] ftdi_sio ttyUSB0: ftdi_set_termios FAILED to set databits/stopbits/parity
The message does not arrive to the device.
I have tried with different usb cables but no success.
I have tried also to provide separate power to the usb cable using a second usb in the following hardware configuration:
  • (vcc+gnd) from 1 usb A connected to PC
  • (tx,rx,gnd) from 1 usb A connected to Spacelynk
Any idea why this is happening?
How can I approach this problem?
Thank you
Spacelynk USB communication towards FTDI - by spapantoniou85 - 06.02.2023, 10:12
