Make the text blink when the value is 1
Hi.
Im trying to use this code:
$(function() {   $('.java_test').each(function(_, el) {     var addr = $(el).data('object');     if (addr) {       grp.listen(addr, function(obj) {         var color_1;         if (obj.value) {           color_1 = 'red';         }         else  {           color_1 = 'Green';         }         $(el).css('color_1',obj.value).toggleClass('class_for_1', obj.value);       });     }   }); });
to toggle a css class. For value 1 i would like to set css class f.e. class_for_1 with parameter filter: drop-shadow (x1, y1, b1, c1), if value is 0 class should be changed to class_for_0 with parameter filter: drop-shadow (x2, y2, b2, c2). It's working only for value=1. Please help.
RE: Make the text blink when the value is 1 - by Re-G - 12.02.2023, 18:04
