Universal Modbus TCP/RTU Slave
#39
(07.03.2023, 07:59)Fahd Wrote:
(06.03.2023, 15:16)Daniel Wrote: Try changing [1] in line 10 to
[*] it will be any slave nr.
Thanks, it works.
but there's something strange if the value is over 20 on the logic machine 5  for example 21 the Modbus pool reader will read it as 30, if it's 22 will read it as 31.4, and so on...
please see attached
I also encountered the same problem when using the "user. mbtcp" script. The value of the data address is 3300, but the value of the mapped 2-byte floating point KNX group address is 33.00.
Another problem is that I added "holding registers" to map the address table, but it doesn't work.
This is my address mapping list:
mb.setmapping({   [7] = {     coils = {       [1] = '0/0/1',       [2] = '0/0/2',       [3] = '0/0/3',     },     registers = {       [1] = '0/1/1',       [2] = '0/1/2',       [3] = '0/1/3',     } ,     holdingregisters = {       [1] = '0/1/4',       [2] = '0/1/5',     }   } })
Universal Modbus TCP/RTU Slave - by Daniel - 07.10.2022, 12:55
RE: Universal Modbus TCP Slave - by palomino - 07.10.2022, 17:30
RE: Universal Modbus TCP Slave - by Daniel - 07.10.2022, 17:53
RE: Universal Modbus TCP Slave - by Daniel - 07.10.2022, 17:55
RE: Universal Modbus TCP Slave - by palomino - 10.10.2022, 13:39
RE: Universal Modbus TCP Slave - by Daniel - 10.10.2022, 13:44
RE: Universal Modbus TCP Slave - by palomino - 11.10.2022, 16:22
RE: Universal Modbus TCP Slave - by palomino - 23.02.2023, 12:44
RE: Universal Modbus TCP Slave - by admin - 23.02.2023, 12:47
RE: Universal Modbus TCP Slave - by palomino - 24.02.2023, 12:41
RE: Universal Modbus TCP Slave - by admin - 24.02.2023, 12:48
RE: Universal Modbus TCP Slave - by palomino - 27.02.2023, 13:02
RE: Universal Modbus TCP Slave - by Daniel - 27.02.2023, 13:10
RE: Universal Modbus TCP Slave - by palomino - 27.02.2023, 14:00
RE: Universal Modbus TCP Slave - by Daniel - 27.02.2023, 14:03
RE: Universal Modbus TCP Slave - by palomino - 28.02.2023, 02:32
RE: Universal Modbus TCP Slave - by admin - 28.02.2023, 07:02
RE: Universal Modbus TCP Slave - by Fahd - 06.03.2023, 14:11
RE: Universal Modbus TCP Slave - by Daniel - 06.03.2023, 14:35
RE: Universal Modbus TCP Slave - by Fahd - 06.03.2023, 14:50
RE: Universal Modbus TCP Slave - by Daniel - 06.03.2023, 14:55
RE: Universal Modbus TCP Slave - by Daniel - 06.03.2023, 15:16
RE: Universal Modbus TCP Slave - by Fahd - 07.03.2023, 07:59
RE: Universal Modbus TCP Slave - by rw_echo - 14.03.2023, 05:22
RE: Universal Modbus TCP Slave - by Daniel - 07.03.2023, 11:55
RE: Universal Modbus TCP Slave - by rw_echo - 07.03.2023, 12:32
RE: Universal Modbus TCP Slave - by Daniel - 07.03.2023, 12:34
RE: Universal Modbus TCP Slave - by rw_echo - 07.03.2023, 12:49
RE: Universal Modbus TCP Slave - by Daniel - 07.03.2023, 12:59
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 15:40
RE: Universal Modbus TCP Slave - by admin - 13.03.2023, 15:42
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 15:58
RE: Universal Modbus TCP Slave - by Daniel - 13.03.2023, 16:00
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 16:07
RE: Universal Modbus TCP Slave - by Daniel - 13.03.2023, 16:15
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 16:32
RE: Universal Modbus TCP Slave - by Daniel - 13.03.2023, 16:41
RE: Universal Modbus TCP Slave - by admin - 13.03.2023, 16:45
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 19:31
RE: Universal Modbus TCP Slave - by admin - 14.03.2023, 06:18
RE: Universal Modbus TCP Slave - by rw_echo - 14.03.2023, 07:39
RE: Universal Modbus TCP Slave - by Fahd - 14.03.2023, 08:27
RE: Universal Modbus TCP Slave - by admin - 14.03.2023, 08:15
RE: Universal Modbus TCP Slave - by rw_echo - 14.03.2023, 08:35
RE: Universal Modbus TCP Slave - by admin - 14.03.2023, 08:35
RE: Universal Modbus TCP/RTU Slave - by admin - 06.06.2023, 15:34
RE: Universal Modbus TCP/RTU Slave - by admin - 12.06.2023, 08:59
RE: Universal Modbus TCP/RTU Slave - by admin - 28.03.2024, 08:26
RE: Universal Modbus TCP/RTU Slave - by admin - 12.06.2024, 05:26
RE: Universal Modbus RTU - by Ranjeet - 14.06.2024, 07:24
RE: Universal Modbus TCP/RTU Slave - by admin - 12.07.2024, 07:14
RE: Universal Modbus TCP/RTU Slave - by admin - 16.04.2025, 07:06
RE: Universal Modbus TCP/RTU Slave - by admin - 22.04.2025, 05:32
RE: Universal Modbus TCP/RTU Slave - by admin - 22.04.2025, 09:01
RE: Universal Modbus TCP/RTU Slave - by admin - 14.08.2025, 09:11
RE: Universal Modbus TCP/RTU Slave - by admin - 25.05.2026, 09:30
RE: Universal Modbus TCP/RTU Slave - by admin - 25.05.2026, 09:47
