28.03.2023, 09:54
(28.03.2023, 07:53)admin Wrote: The connection is only dropped for public IP ranges. NAT mode should work over ZeroTier as it uses private address ranges. Maybe your routing is not configured correctly. Can you access LM web UI this way?
Hmm.... maybe sometime earlier I've made some mistake in configuration. Now it works correctly with NAT mode... Thank you!
