19.04.2023, 15:26
(19.04.2023, 07:31)Daniel Wrote: The last sentence is not correct, If you select tunneling then LM will connect to another IP interface via tunneling. You can connect to LM via tunneling always as long KNX IP features are enabled. If you use only secure communication then this will also disable tunneling as this part is not secured yet.
Ok, understood!
Thanks!
