Trouble after power failure
(18.05.2023, 10:19)Daniel Wrote: Please simulate the power failure again and then scan the line and scan the device, see if configuration are there and groups assigned. If not then device need replacement.
The project is being completed, to be safe, the CB will be turned off at night and the CB will be turned on the next morning. I do a line scan and I still see the device's address, but when I write or read the address in the groups, it doesn't respond. I write configuration again each device, the device works normally. In the event of a power outage, the customer will contact me regarding the loss of control. Can you check this for me? Thank you!
Trouble after power failure - by aicanx - 18.05.2023, 08:04
RE: Trouble after power failure - by Daniel - 18.05.2023, 10:19
RE: Trouble after power failure - by aicanx - 18.05.2023, 11:08
RE: Trouble after power failure - by Daniel - 18.05.2023, 12:18
RE: Trouble after power failure - by aicanx - 19.05.2023, 08:46
RE: Trouble after power failure - by Daniel - 19.05.2023, 08:50
RE: Trouble after power failure - by aicanx - 19.05.2023, 10:53
RE: Trouble after power failure - by hoangknx - 12.06.2023, 07:09
RE: Trouble after power failure - by Daniel - 12.06.2023, 07:28
RE: Trouble after power failure - by admin - 12.06.2023, 13:30
