IrrigationCaddy integration module
<- EDIT: updated version, download it again and look at last post for changes. ->
here is a module for interacting with IrrigationCaddy controller.
As usual you can find module and example attached.
I use two event based script. I trigger them for updating status or updating configuration use a KNX group.
The script for updating the status is:
old_print = print debug_level = 0 print = function(...)  if ( verbose ) then    log(...)   end end irrigationcaddy = require("user.IrrigationCaddy") syslog_level = ERR verbose = false irrigationcaddy.ip = "192.168.1.100" irrigationcaddy.update() print ( string.format ( "IC status %s", irrigationcaddy.allowRun ) ) ic = grp.getvalue ( '0/1/40' ) ic_status = grp.getvalue ( '0/1/41' ) if ( ic_status ~= irrigationcaddy.allowRun ) then print ( string.format ( "IC status (%s) different from device (%s)", tostring(ic_status), tostring(irrigationcaddy.allowRun) ) ) grp.write ( '0/1/41', irrigationcaddy.allowRun, dt.boolean ) end
The script for updating the configuration is:
irrigationcaddy = require("user.IrrigationCaddy") debug_level = 5 verbose = true irrigationcaddy.ip = "192.168.168.73" ic = grp.getvalue ( '0/1/40' ) ic_status = grp.getvalue ( '0/1/41' ) print ( string.format ( 'Evento da %s per %s tipo %s', event['src'], event['dst'], event['type']) ) group = event['dst'] if ( group == '0/1/40' ) then     if ( ic_status ~= ic ) then    print ( string.format ( "Changing IC status (%s)  to %s", tostring(ic_status), tostring(ic) ) )    if ( ic == false ) then      irrigationcaddy.disable()    elseif ( ic == true ) then      irrigationcaddy.enable()    end    grp.write( '0/1/49', true, dt.boolean )     end end
Finally the script that triggers the update is:
log ( 'Triggering IC update' ) grp.write('0/1/49', true, dt.boolean ) return
Where group 0/1/49 is the triggering group.
I've chosen this approach to trigger update on configuration and on scheduled base.
Luca
.lua   irrigationcaddy.lua (Size: 11.93 KB / Downloads: 12)
.lua   testirrigationcaddy.lua (Size: 805 bytes / Downloads: 6)
IrrigationCaddy integration module - by lpala - 24.01.2017, 21:06
