Thanks Erwin I thinked about similar solution but this works perfect with interval 500ms
And if it is about auto opening widgets on first opening script must remove class '.hide' and change display to 'block' and after that it only must change this second attribute.
But I see a problem with this first opening widget, because when I use this two functions (it is not important which is first) the first opening is a bug(widget is very big and not in a right position on a screen). But I will check this tommorrow
