Tag mass edit
Some years ago I made this script, now would do it differently but still  will work.
seperators = '.,_ =+' -- Start address of objects (min: 0/0/1 = main/sub/address) start_main = 0 start_sub = 0 start_address = 1 -- End address of objects (max: 31/7/255 = main/sub/address) end_main = 15 end_sub = 7 end_address = 255 ------------------------------------------ End Parameters ------------------------------------------ ------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE ------------------------------- function split(source, delimiters)         local elements = {}         local pattern = '([^'..delimiters..']+)'         string.gsub(source, pattern, function(value) elements[#elements + 1] =     value;  end);         return elements end -- Calculate start address to DB format start_objectaddress = ((start_main * 2048) + (start_sub * 256) + start_address) -- Calculate end address to DB format end_objectaddress = ((end_main * 2048) + (end_sub * 256) + end_address) -- Get all objects from DB all_objects = db:getall('SELECT address, name, tagcache FROM objects') for _, object in ipairs(all_objects) do   -- Check if object is inside given range   if object.address >= start_objectaddress and object.address <= end_objectaddress then      currentrowaddress = object.address     myobject = grp.find(currentrowaddress)     nameTable = split(myobject.name, seperators)  --spliting  object string in to table       --  log(nameTable)     for _, tag in ipairs(nameTable) do       tagvalue = tag            -- Check if object tag already exists inside DB      current_object_tag = db:getall('SELECT object, tag FROM objecttags WHERE object = ' .. currentrowaddress .. ' AND tag = "' .. tagvalue .. '"')      object_tagcache = db:getone('SELECT tagcache FROM objects WHERE address = ' .. currentrowaddress .. '')      if #current_object_tag == 0 then         -- Add object to table objecttags         db:insert('objecttags', {object = currentrowaddress, tag = tagvalue, })           -- Check if object already has other tag values inside DB and add new values to tagcache         if object_tagcache == nil or object_tagcache == "" then           db:update('objects', { tagcache = tagvalue }, { address = currentrowaddress })             else           tag_string = "" .. object_tagcache .. ", " .. tagvalue .. ""                log(tag_string)           db:update('objects', { tagcache = tag_string }, { address = currentrowaddress })           end      end         end   end end script.disable(_SCRIPTNAME)
Tag mass edit - by Novodk - 23.07.2023, 13:58
RE: Tag mass edit - by Daniel - 24.07.2023, 07:24
RE: Tag mass edit - by Novodk - 27.07.2023, 21:15
RE: Tag mass edit - by Daniel - 28.07.2023, 07:32
RE: Tag mass edit - by Novodk - 28.07.2023, 15:17
