Broker.BrokerClient
Hi. My Logs has just started to fill up with events from script "Broker.BrokerClient" with different messages which I do not understand and I am not quite sure where to start to get rid of the issue with flooded loggs. I tried to disable most scrpipts with no luck - so based on a couple of searches I suspect this to be modbus related. There are 1 modbus RTU device (Ventilation system - Seems to work like it should) and there are 9 TCP modbus connections (Scheneider Power Tag modules).
Any ideas where the problem lays based on the log below?
Logg
[Image: 202307_wiserLogs.png]
Error Logg (PNG)
* arg: 1
  * string: [DEBUG]
* arg: 2
  * string:
BROKER_CLIENT:
* arg: 3
  * string: DEBUG 5310:
* arg: 4
  * string:
RPC_SOCKET_CLIENT:
* arg: 5
  * string: DEBUG 3924:
* arg: 6
  * string: Step RPC server on_message call
Wiser for KNXLogoutStart pageLanguage:
English
Version: 2.8.3
CPU/IO: 0.09 0.16 0.19, Memory: 17% Disk: 27%, KNX/TP: OK
* arg: 1
  * string: [DEBUG]
* arg: 2
  * string:
BROKER_CLIENT:
* arg: 3
  * string: DEBUG 5318:
* arg: 4
  * string: RpcClient:on_message:
* arg: 5
  * table:
  ["headers"]
    * table:
    ["timestamp"]
      * number: 1690395032
    ["user-id"]
      * string: APIT3
    ["content-type"]
      * string: application/json
  ["command"]
    * string: RESPONSE_HEARTBEAT
Broker.BrokerClient - by stemic01 - 26.07.2023, 18:11
RE: Broker.BrokerClient - by Daniel - 27.07.2023, 07:24
RE: Broker.BrokerClient - by stemic01 - 27.07.2023, 18:59
RE: Broker.BrokerClient - by Daniel - 28.07.2023, 07:37
RE: Broker.BrokerClient - by stemic01 - 28.07.2023, 16:43
RE: Broker.BrokerClient - by Daniel - 28.07.2023, 16:44
RE: Broker.BrokerClient - by stemic01 - 02.08.2023, 08:44
