06.10.2023, 08:46
(05.10.2023, 13:36)Daniel Wrote: Do not worry about Mosaic for now, first you must read data from modbus and then write it to object. Later you will select a widget you want and map this object to widget and job done.
Now when you have the settings is time to create profile in json format. All the parameters of the file you can find here:
https://openrb.com/docs/modbus.htm
I created for you the starting point(see attached) and you can just eddit it and copy paste and change parameters. Notepadd++ is a good tool to use.
Once all is done you must import this profile to LM, then add device with addres 1 and select your profile.
Next step is to mapp or create objects. Once device is created just click on mapping and finish the job.
If all goes well you should see values under objects tab.
If all this work then you can move to Mosaic.
PS. Each time you change profile you must delete device from LM and add it again.
Powodzenia
Dziękuję , już rozumiem o co chodzi
