Sauna RS485 connection with LM
Hi.
I get response timeout when running this script in wiser knx. is there any difference for RS-485 port?
I´ve tested this script over here and also with
This:
require('serial') local port, errorMsg = serial.open('/dev/RS485', { baudrate = 57600, parity = 'none', duplex = 'half', databits = 8, stopbits = 1 }) -- Kontrollera om porten öppnades framgångsrikt if not port then     log("Kunde inte öppna porten: " .. (errorMsg or "Okänt fel"))     return end port:flush() -- Funktion för att läsa svar från bastun local function readack()   local line = {}   while true do     local char, err = port:read(1, 5)     if char == nil then       return nil, err     elseif char == ';' then       break     else       table.insert(line, char)     end   end   return table.concat(line) end -- Kontrollera om bastun ska vara PÅ eller AV local bastuState = grp.getvalue('37/1/1') if bastuState then     port:write('set sauna on\r') else     port:write('set sauna off\r') end -- Ställ in bastutemperaturen baserat på KNX-gruppadressen, värde mellan 30-110 grader local temperature = grp.getvalue('37/1/3') port:write('set sauna val ' .. temperature .. '\r') -- Läs tillbaka värdet från bastun port:write('get sauna val\r') local res, err = readack() if res then     log("Sauna värde: " .. res)     grp.checkwrite('37/1/0', res)  -- Skriver bastustatus till angiven adress     grp.checkwrite('37/1/4', res)  -- Skriver tillbaka temperaturstatus till den nya gruppadressen else     log("Fel vid läsning av bastu värde: " .. (err or "Okänt fel")) end -- Stäng porten port:close()
Anone who can see something wrong in this script?
RE: Sauna RS485 connection with LM - by admin - 09.11.2018, 08:32
RE: Sauna RS485 connection with LM - by admin - 09.11.2018, 09:46
RE: Sauna RS485 connection with LM - by victor.back - 06.10.2023, 12:15
RE: Sauna RS485 connection with LM - by admin - 06.10.2023, 12:43
RE: Sauna RS485 connection with LM - by admin - 13.12.2023, 08:31
RE: Sauna RS485 connection with LM - by admin - 13.12.2023, 08:39
RE: Sauna RS485 connection with LM - by admin - 13.12.2023, 11:19
