HDL Buspro gateway integration with LM5
Try this updated library. Let us know if it works so we can update the example on our website.
local socket = require('socket') local crc16 = require('encdec').crc16 local ifinfo = require('ifinfo') HDL = {   -- destination ip   dstip = '192.168.0.2',   -- packet constant data   magic = 'HDLMIRACLE',   lcode = string.char(0xAA, 0xAA),   -- source device settings   srcsubnet = 1,   srcdevice = 254,   devicetype = 0xFFFE,   -- command types   cmd = {     chanreg = 0x0031, -- single channel regulate     chanregreply = 0x0032, -- single channel regulate answerback     chanstat = 0x0033, -- read status of single channel targets     chanstatreply = 0x0034, -- single channel targets status answerback   } } HDL.init = function()   local info, chunk, chunks   info = ifinfo()   if not info or not info.eth0 then     error('cannot get interface info')   end   -- ip header   HDL.iphdr = ''   -- broadcast address   HDL.bcast = info.eth0.bcast   -- split ip address into chunks   chunks = info.eth0.inetaddr:split('.')   -- add ip address chunks   for i = 1, 4 do     chunk = tonumber(chunks[ i ])     HDL.iphdr = HDL.iphdr .. string.char(chunk)   end end HDL.decode = function(packet)   local len, data, src, crc   -- primary header   if packet:sub(5, 14) ~= HDL.magic then     return nil, 'magic'   end   -- leading code   if packet:sub(15, 16) ~= HDL.lcode then     return nil, 'lcode'   end   -- get data length and check against   len = packet:byte(17)   if len and len + 16 ~= packet:len() then     return nil, 'len'   end   -- get packet data and check crc   data = packet:sub(17, len + 14)   crc = packet:byte(len + 15) * 0x100 + packet:byte(len + 16)   if crc16(data) ~= crc then     return nil, 'crc'   end   -- return parsed packet   return {     srcip = string.format('%d.%d.%d.%d', packet:byte(1, 4)),     srcsubnet = packet:byte(18),     srcdevice = packet:byte(19),     devicetype = (packet:byte(20) * 0x100 + packet:byte(21)),     opcode = (packet:byte(22) * 0x100 + packet:byte(23)),     dstsubnet = packet:byte(24),     dstdevice = packet:byte(25),     additional = packet:sub(26, len + 14)   } end HDL.word = function(v)   return string.char(bit.band(bit.rshift(v, 8), 0xFF), bit.band(v, 0xFF)) end HDL.encode = function(cmd, dstsubnet, dstdevice, extra)   local packet, len, crc, data   -- perform init if required   if not HDL.iphdr then     HDL.init()   end   -- start packet: ip, magic and leading code   packet = { HDL.iphdr, HDL.magic, HDL.lcode }   -- base data   data = string.char(HDL.srcsubnet, HDL.srcdevice) ..     HDL.word(HDL.devicetype) ..     HDL.word(cmd) ..     string.char(dstsubnet, dstdevice)   -- add extra data parameters   if type(extra) == 'string' then     data = data .. extra   end   -- calculate length and crc   len = string.char(data:len() + 3)   crc = crc16(len .. data)   table.insert(packet, len)   table.insert(packet, data)   table.insert(packet, HDL.word(crc))   return table.concat(packet) end HDL.send = function(packet)   local client = socket.udp()   client:sendto(packet, HDL.dstip, 6000) end HDL.chanreg = function(dstsubnet, dstdevice, chan, value, delay)   local extra, packet   delay = delay or 0   if type(value) == 'boolean' then     value = value and 100 or 0   end   extra = string.char(chan, value) .. HDL.word(delay)   packet = HDL.encode(HDL.cmd.chanreg, dstsubnet, dstdevice, extra)   HDL.send(packet) end
RE: HDL Buspro gateway integration with LM5 - by admin - 25.10.2023, 06:36
