(31.10.2023, 16:45)Daniel Wrote: Maybe you didn't perform the reset correctly, it is easy to miss a step. Do as fallow.
Press reset button and LED2 will go RED.
Wait till LED2 will start flashing RED
Release the button and press again, LED2 will go RED
Wait till LED will start flashing faster and then release
If you see same LED behavior then reset was done correctly and LM will have IP 192.168.0.10
This still does not explain why network LEDs are off.
Ok I did it and it is still in the same way.
(31.10.2023, 16:47)Daniel Wrote:(31.10.2023, 16:45)AngelesTR Wrote: Could It be right if I reinstall the firmware?
How do you want to do it if you can't connect to it?
You can always flash the SD card to fresh firmware if nothing helps.
ok, i'll try this
