14.11.2023, 11:01
(14.11.2023, 06:42)carlo72 Wrote: My network is the one attached. I have to send normal telegrams, not system ones. Since multicast does not work in my system's network, I have to connect from time to time to an IP router in tunneling with the LM (LSS100200). In fact I can do it by setting the KNX interface of the LM to Tunneling mode, but it can only be done from the settings by restarting the LM from time to time. I would need to write a script that, based on the address, is capable of changing the host of the tunneling setting without going through the settings, dynamically
it should be cool to test with one ip interface as coupler for example, and connect LM with TP to it (with a powersupply knx on it).
but hard without knowing the whole Structure...
you should have in this case for example
![[Image: Topology-Couplers.png]](https://support.knx.org/hc/article_attachments/360000521580/Topology-Couplers.png)
https://support.knx.org/hc/fr/articles/1...-coupleurs
and specially page 10
https://www.hqs.sbt.siemens.com/cps_prod..._RS-AC.pdf
SE ECO EXPERT
SE ECO EXPERT
