config sync failed for mosaic
(06.12.2023, 13:17)Andrea Becagli Wrote: ah ok that makes more sense. I have the latest available 20230607.
Might this be a problem with TCP ports? Because the whole system is under a LTE Modem
Run this script once
function checktcp(ip, port)   local sock = require('socket').tcp()   sock:settimeout(1)   local res, err = sock:connect(ip, port)   sock:close()   return res, err end -- change IP/PORT as needed res, err = checktcp('remote.logicmachine.net', 8883) if res then   log('connect OK') else   log('connect ERROR', err) end
And then once more but change port to 443
send logs
RE: config sync failed for mosaic - by Daniel - 06.12.2023, 11:22
RE: config sync failed for mosaic - by Daniel - 06.12.2023, 12:17
RE: config sync failed for mosaic - by Daniel - 06.12.2023, 13:10
RE: config sync failed for mosaic - by Daniel - 06.12.2023, 13:21
RE: config sync failed for mosaic - by Daniel - 06.12.2023, 13:28
