Shelly - WiFi IoT-Devices
#29
Hi, with the above code, you use broadcast topic "shellies". If I use a topic set in a device, eg a ShellyPluss1 (relay) eith add-on module, how can i sort the different values on the same topic?
I made this based on the above, but it only works on th ebinary status object, not temperature:
function conv_shellyRelay(payload, numberRel, target_s_addr)   local data = require('json').pdecode(payload)     if type(data) == 'table' then       grp.write(target_s_addr, data["params"][numberRel]["output"])       log(data.bat.value)       return data.bat.value   end end         function conv_shellyTemp(payload, numberTemp, target_t_addr)   local data = require('json').pdecode(payload)     if type(data) == 'table' then       log(data["params"][numberTemp]["tC"])         grp.write(target_t_addr, data["params"][numberTemp]["tC"])     return data.bat.value   end end     -- topic to object map   mqtt_to_object = {     ['Shelly/events/rpc']         = '33/1/8', -- Temperature 1     ['Shelly/events/rpc']         = '33/1/9',    -- Status relay       ['Shelly/events/rpc']         = '33/1/10',-- Temperature 2   }       mqtt_to_object_conv = {       ['Shelly/events/rpc'] = function(payload)    return conv_shellyTemp(payload,"temperature:100", '33/1/8')   end,            ['Shelly/events/rpc'] = function(payload)    return conv_shellyTemp(payload,"temperature:101", '33/1/10')   end,          ['Shelly/events/rpc'] = function(payload)    return conv_shellyRelay(payload,"switch:0", '33/1/9')   end,          }   -- object to topic map   object_to_mqtt = {        ['33/1/7']     = 'Shelly/command/switch:0', }
Shelly - WiFi IoT-Devices - by Todayslife - 24.11.2020, 13:27
RE: Shelly - WiFi IoT-Devices - by admin - 24.11.2020, 13:35
RE: Shelly - WiFi IoT-Devices - by Todayslife - 28.11.2020, 14:31
RE: Shelly - WiFi IoT-Devices - by admin - 28.11.2020, 14:55
RE: Shelly - WiFi IoT-Devices - by Todayslife - 28.11.2020, 15:41
RE: Shelly - WiFi IoT-Devices - by admin - 30.11.2020, 07:21
RE: Shelly - WiFi IoT-Devices - by admin - 26.12.2020, 16:28
RE: Shelly - WiFi IoT-Devices - by admin - 28.12.2020, 07:49
RE: Shelly - WiFi IoT-Devices - by a455115 - 20.06.2022, 13:14
RE: Shelly - WiFi IoT-Devices - by a455115 - 13.10.2022, 14:26
RE: Shelly - WiFi IoT-Devices - by admin - 22.06.2022, 09:27
RE: Shelly - WiFi IoT-Devices - by a455115 - 24.06.2022, 10:21
RE: Shelly - WiFi IoT-Devices - by admin - 27.06.2022, 12:24
RE: Shelly - WiFi IoT-Devices - by a455115 - 29.06.2022, 13:45
RE: Shelly - WiFi IoT-Devices - by a455115 - 30.06.2022, 15:12
RE: Shelly - WiFi IoT-Devices - by admin - 30.06.2022, 15:19
RE: Shelly - WiFi IoT-Devices - by a455115 - 05.07.2022, 06:17
RE: Shelly - WiFi IoT-Devices - by admin - 01.07.2022, 06:09
RE: Shelly - WiFi IoT-Devices - by admin - 05.07.2022, 06:36
RE: Shelly - WiFi IoT-Devices - by a455115 - 05.07.2022, 10:40
RE: Shelly - WiFi IoT-Devices - by admin - 14.10.2022, 06:17
RE: Shelly - WiFi IoT-Devices - by a455115 - 17.10.2022, 09:53
RE: Shelly - WiFi IoT-Devices - by admin - 17.10.2022, 10:00
RE: Shelly - WiFi IoT-Devices - by a455115 - 17.10.2022, 14:51
RE: Shelly - WiFi IoT-Devices - by a455115 - 20.10.2022, 06:48
RE: Shelly - WiFi IoT-Devices - by admin - 20.10.2022, 07:44
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 10:12
RE: Shelly - WiFi IoT-Devices - by admin - 03.01.2024, 10:19
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 10:26
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 14:46
RE: Shelly - WiFi IoT-Devices - by admin - 03.01.2024, 15:00
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 08:51
RE: Shelly - WiFi IoT-Devices - by admin - 16.01.2024, 09:03
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 09:49
RE: Shelly - WiFi IoT-Devices - by admin - 16.01.2024, 09:50
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 09:54
