Shelly - WiFi IoT-Devices
#31
(03.01.2024, 10:19)admin Wrote: You have duplicate keys in mqtt_to_object and mqtt_to_object_conv - this won't work. If multiple devices share the same topic then you need to manually implement logic for distinguishing what kind of data is received and which object must be updated.
Ok, I was afraid of that. So i need to make logic that only reads topic once, and then sorts out the different values I'm looking for.
So I made a function to look up certain names in the table, is there any way to have the mqtt_to_object run without a GA attached? It will only run the first grp.write:
function conv_shellyTemp(payload)   local data = require('json').pdecode(payload)        if type(data) == 'table' then                function tableHasKey(table, prefix)                         for key, _ in pairs(table) do                       --log(key)                         if string.match(key, prefix) then                         return true                         end                         end                         return false                         end          if tableHasKey(data["params"],"temperature") then                    grp.write('33/1/8', data["params"]["temperature:100"]["tC"])                 grp.write('33/1/10', data["params"]["temperature:101"]["tC"])        elseif             tableHasKey(data["params"],"switch") then                    grp.write('33/1/9', data["params"]["switch:0"]["output"])           else         log("no data")         end     end   end
Shelly - WiFi IoT-Devices - by Todayslife - 24.11.2020, 13:27
RE: Shelly - WiFi IoT-Devices - by admin - 24.11.2020, 13:35
RE: Shelly - WiFi IoT-Devices - by Todayslife - 28.11.2020, 14:31
RE: Shelly - WiFi IoT-Devices - by admin - 28.11.2020, 14:55
RE: Shelly - WiFi IoT-Devices - by Todayslife - 28.11.2020, 15:41
RE: Shelly - WiFi IoT-Devices - by admin - 30.11.2020, 07:21
RE: Shelly - WiFi IoT-Devices - by admin - 26.12.2020, 16:28
RE: Shelly - WiFi IoT-Devices - by admin - 28.12.2020, 07:49
RE: Shelly - WiFi IoT-Devices - by a455115 - 20.06.2022, 13:14
RE: Shelly - WiFi IoT-Devices - by a455115 - 13.10.2022, 14:26
RE: Shelly - WiFi IoT-Devices - by admin - 22.06.2022, 09:27
RE: Shelly - WiFi IoT-Devices - by a455115 - 24.06.2022, 10:21
RE: Shelly - WiFi IoT-Devices - by admin - 27.06.2022, 12:24
RE: Shelly - WiFi IoT-Devices - by a455115 - 29.06.2022, 13:45
RE: Shelly - WiFi IoT-Devices - by a455115 - 30.06.2022, 15:12
RE: Shelly - WiFi IoT-Devices - by admin - 30.06.2022, 15:19
RE: Shelly - WiFi IoT-Devices - by a455115 - 05.07.2022, 06:17
RE: Shelly - WiFi IoT-Devices - by admin - 01.07.2022, 06:09
RE: Shelly - WiFi IoT-Devices - by admin - 05.07.2022, 06:36
RE: Shelly - WiFi IoT-Devices - by a455115 - 05.07.2022, 10:40
RE: Shelly - WiFi IoT-Devices - by admin - 14.10.2022, 06:17
RE: Shelly - WiFi IoT-Devices - by a455115 - 17.10.2022, 09:53
RE: Shelly - WiFi IoT-Devices - by admin - 17.10.2022, 10:00
RE: Shelly - WiFi IoT-Devices - by a455115 - 17.10.2022, 14:51
RE: Shelly - WiFi IoT-Devices - by a455115 - 20.10.2022, 06:48
RE: Shelly - WiFi IoT-Devices - by admin - 20.10.2022, 07:44
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 10:12
RE: Shelly - WiFi IoT-Devices - by admin - 03.01.2024, 10:19
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 10:26
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 14:46
RE: Shelly - WiFi IoT-Devices - by admin - 03.01.2024, 15:00
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 08:51
RE: Shelly - WiFi IoT-Devices - by admin - 16.01.2024, 09:03
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 09:49
RE: Shelly - WiFi IoT-Devices - by admin - 16.01.2024, 09:50
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 09:54
