Several issues after LM restoration
(10.01.2024, 17:24)Daniel Wrote: If LM is saving project to SD while power failure will happen the corruption can still happen but we will run some further tests to see if we still have some issue.
Login to cloud as admin user and close mosaic and go to settings. You should see there two networks. Try deleting the old one. You also have multiple networks enabled.
Daniel hi.
Regarding cloud networks, as you can see in the screenshot,  there is no old one but only the active network. The strange behavior is happening to the customer account.
Regarding saving the project to SD what do you mean by IF? Is there an option not to do that? I thought projects were not saved to SD cards.
RE: Several issues after LM restoration - by Livadi77 - 11.01.2024, 07:24
