Force 2 digit
you can try as Domotiqa recommended. Possible variant - show your data with zeroes, when you need enter data - zero is not so important may be.
Long time ago I did something you need with hour and minutes less 10, I wanted zero in front:
time = { day = wday, hour = now.hour, minute = now.min, second = now.sec, } h1 = now.hour m1 = now.min ms = now.month weekday1 = wday if now.hour == 0 then h1 = "00" end if now.hour == 1 then h1 = "01" end if now.hour == 2 then h1 = "02" end if now.hour == 3 then h1 = "03" end if now.hour == 4 then h1 = "04" end if now.hour == 5 then h1 = "05" end if now.hour == 6 then h1 = "06" end if now.hour == 7 then h1 = "07" end if now.hour == 8 then h1 = "08" end if now.hour == 9 then h1 = "09" end if now.min == 0 then m1 = "00" end if now.min == 1 then m1 = "01" end if now.min == 2 then m1 = "02" end if now.min == 3 then m1 = "03" end if now.min == 4 then m1 = "04" end if now.min == 5 then m1 = "05" end if now.min == 6 then m1 = "06" end if now.min == 7 then m1 = "07" end if now.min == 8 then m1 = "08" end if now.min == 9 then m1 = "09" end if now.hour == 0 then h1 = "00" end if weekday1 == 1 then weekdayru = "Понедельник" end if weekday1 == 2 then weekdayru = "Вторник" end if weekday1 == 3 then weekdayru = "Среда" end if weekday1 == 4 then weekdayru = "Четверг" end if weekday1 == 5 then weekdayru = "Пятница" end if weekday1 == 6 then weekdayru = "Суббота" end if weekday1 == 7 then weekdayru = "Воскресенье" end
Simple but works. In result I see time with zeroes in front and weekdays text in required language. This is just like an idea. And of course you need take in mind data types and convert it if needed..
Alex
Force 2 digit - by jmir - 03.11.2023, 07:12
RE: Force 2 digit - by Daniel - 03.11.2023, 08:33
RE: Force 2 digit - by jmir - 06.11.2023, 10:58
RE: Force 2 digit - by Daniel - 06.11.2023, 11:29
RE: Force 2 digit - by jmir - 07.11.2023, 09:45
RE: Force 2 digit - by domotiqa - 11.01.2024, 15:16
RE: Force 2 digit - by AlexLV - 11.01.2024, 21:50
RE: Force 2 digit - by admin - 12.01.2024, 08:51
