Shelly - WiFi IoT-Devices
#34
["thermostats"]   * table:    [1]     * table:      ["valve_min_percent"]       * number: 0      ["t_auto"]       * table:        ["enabled"]         * bool: true      ["target_t"]       * table:        ["units"]         * string: C        ["value_op"]         * number: 8        ["enabled"]         * bool: true        ["accelerated_heating"]         * bool: true        ["value"]         * number: 7      ["extra_pressure"]       * bool: false      ["calibration_correction"]       * bool: true      ["schedule_profile_names"]       * table:        [1]         * string: Livingroom        [2]         * string: Livingroom 1        [3]         * string: Bedroom        [4]         * string: Bedroom 1        [5]         * string: Holiday      ["schedule_profile"]       * number: 1      ["open_window_report"]       * bool: false      ["boost_minutes"]       * number: 30      ["valve_min_report"]       * number: 1      ["force_close"]       * bool: false      ["schedule_rules"]       * table:        [1]         * string: 0600-0123456-23        [2]         * string: 2300-0123456-18      ["ext_t"]       * table:        ["floor_heating"]         * bool: false        ["enabled"]         * bool: true      ["schedule"]       * bool: false      ["temperature_offset"]       * number: 0
I am trying to write to the object "temperature_offset" but i can not get the syntax right.
"'shellies/TRV_ROM1/settings/thermostats  . .. "
It is stated as a parameter in the documentation for mqtt.
https://shelly-api-docs.shelly.cloud/gen...rmostats-0
The http command is:
http://10.xxx.xxx.xxx/ext_t?temp=measured t°
Shelly - WiFi IoT-Devices - by Todayslife - 24.11.2020, 13:27
RE: Shelly - WiFi IoT-Devices - by admin - 24.11.2020, 13:35
RE: Shelly - WiFi IoT-Devices - by Todayslife - 28.11.2020, 14:31
RE: Shelly - WiFi IoT-Devices - by admin - 28.11.2020, 14:55
RE: Shelly - WiFi IoT-Devices - by Todayslife - 28.11.2020, 15:41
RE: Shelly - WiFi IoT-Devices - by admin - 30.11.2020, 07:21
RE: Shelly - WiFi IoT-Devices - by admin - 26.12.2020, 16:28
RE: Shelly - WiFi IoT-Devices - by admin - 28.12.2020, 07:49
RE: Shelly - WiFi IoT-Devices - by a455115 - 20.06.2022, 13:14
RE: Shelly - WiFi IoT-Devices - by a455115 - 13.10.2022, 14:26
RE: Shelly - WiFi IoT-Devices - by admin - 22.06.2022, 09:27
RE: Shelly - WiFi IoT-Devices - by a455115 - 24.06.2022, 10:21
RE: Shelly - WiFi IoT-Devices - by admin - 27.06.2022, 12:24
RE: Shelly - WiFi IoT-Devices - by a455115 - 29.06.2022, 13:45
RE: Shelly - WiFi IoT-Devices - by a455115 - 30.06.2022, 15:12
RE: Shelly - WiFi IoT-Devices - by admin - 30.06.2022, 15:19
RE: Shelly - WiFi IoT-Devices - by a455115 - 05.07.2022, 06:17
RE: Shelly - WiFi IoT-Devices - by admin - 01.07.2022, 06:09
RE: Shelly - WiFi IoT-Devices - by admin - 05.07.2022, 06:36
RE: Shelly - WiFi IoT-Devices - by a455115 - 05.07.2022, 10:40
RE: Shelly - WiFi IoT-Devices - by admin - 14.10.2022, 06:17
RE: Shelly - WiFi IoT-Devices - by a455115 - 17.10.2022, 09:53
RE: Shelly - WiFi IoT-Devices - by admin - 17.10.2022, 10:00
RE: Shelly - WiFi IoT-Devices - by a455115 - 17.10.2022, 14:51
RE: Shelly - WiFi IoT-Devices - by a455115 - 20.10.2022, 06:48
RE: Shelly - WiFi IoT-Devices - by admin - 20.10.2022, 07:44
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 10:12
RE: Shelly - WiFi IoT-Devices - by admin - 03.01.2024, 10:19
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 10:26
RE: Shelly - WiFi IoT-Devices - by tomnord - 03.01.2024, 14:46
RE: Shelly - WiFi IoT-Devices - by admin - 03.01.2024, 15:00
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 08:51
RE: Shelly - WiFi IoT-Devices - by admin - 16.01.2024, 09:03
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 09:49
RE: Shelly - WiFi IoT-Devices - by admin - 16.01.2024, 09:50
RE: Shelly - WiFi IoT-Devices - by tomnord - 16.01.2024, 09:54
